2CarPros - Car Questions & Answers
Ford F-150 Repair Question
Topics covered: Sensor, Egr valve, Coil pack.
Asked on March 16, 2007
Engine light will not go away
I have a 01 f150 4.2 2x2 5-speed man. About 6 months ago my engine light came on. The code came up EGR pressure and bank 2 fuel too lean. I changed the EGR valve, sensor and solenoid, and i also cleaned out the tube from the exhuast to the EGR valve. A day after clearing the code the light came back on. To make a long story short i'll just tell you what i replaced through the 6 month period; Coil pack, maf sensor, spark plugs & wires,and both O2 sensors. After changing all these parts, my light is still coming on with the same code a day or two after i clear it. I am at a loss. Can you please help.
Avatar Asked by 01F150
Answer
Replied on March 17, 2007
I would be checking for a vacuum leak, if you are getting a code for 1 bank only i would be looking at that side of the inlet manifold to start with.
mark (mhpautos)
Tiny Answered by mhpautos (expert)
26,913 answers provided
Replied on March 20, 2007
with the egr code u may have a bad pressure sensor
Tiny Answered by jacobfegley
1 question asked
