Mechanics
F150 TIMNG CHAIN TENSIONERS
2004 Ford F-150
Engine Mechanical problem
2004 Ford F150 V8 Four Wheel Drive Automatic
I just did a timing chain, guide rails, and tensioners on my f150 5.4 lariot 2004. The front engine noise was a very distinct rattle at initial start up it is still there until the oil pressure builds then the rattle sound goes away. The tensioners do not seem to be holding oil pressure after the engine is shut off, they seem to be bleeding off, it takes about 20 min. Of sitting. Iis there a check valve or a bleedback valve that is faulty that could be causing the tensioner to bleed off its pressure. The old tensioners were spongy when I removed them, I don't think the new ones are performing any different.
Hotrod1969
August 26, 2009.
There are revised cam phasers for noise, as well as recommendations to pull the front cam cap and inspect oil feed line
also make sure you are using 5w20 oil and thicker oil can cause noise
Mjr346
Aug 26, 2009.
AD
