How to change a timing gear on a 1995 300 six cylinder Ford?
Dec 12, 2010 at 7:43 PM
KHLOW2008
CAR REPAIR CONTRIBUTOR
Here is the instructions and marks in the diagrams below. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed. Cheers
Images (Click to enlarge)
Dec 23, 2010 at 2:43 PM
JAM32
MEMBER
1 POST
Replacing timing gears, how to press camshaft gear onto camshaft? Shaft moves back into block when you try to tap gear on. Is there a puller/pusher to get this gear on?
Sep 26, 2018 at 11:57 AM
(Merged)
BLACKOP555
You are supposed to use a hydraulic press to do that. Take it in before you break the gear.
(Merged)
EFRAIN BARO
MEMBER
V8 Automatic 100,000 miles.
What is the timing chain diagram for a Ford F-150 5.4 4x4, 2004?
(Merged)
BLUELIGHTNIN6
(Merged)
