Transfer case stuck in 4wd low
2005 FORD F-150
140,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
RWPADDZ
I turn switch to 2wd will not shift out 4wd low.
Nov 17, 2018 at 7:14 AM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
When you shift, is the transmission in neutral? Also, do you hear any noise from the actuator on the transfer case?
Check fuse 111 in the passenger compartment fuse box. Also, in the auxiliary relay box, locate both 4wd relays. Switch them with other relays with the same part numbers to see if it makes a difference. The relay box is under the hood (driver's side). See picture 4.
Nov 17, 2018 at 7:54 PM
RWPADDZ
Can the coil on the actuator be bad? Can you just replace the coil or the hole actuator has to be replace?
Nov 18, 2018 at 7:32 AM
  • 110,190 POSTS
If you are getting power to the actuator, then yes it is most likely the problem. To the best of my knowledge, you cannot purchase that part separately.
Nov 18, 2018 at 6:20 PM
SHAWN.SMITH
My wife recently informed me that my truck is stuck in four wheel drive low. She recently took a three hundred mile trip and on the way back she hit a snow storm and had to kick it in four wheel drive. She tried switching in/out of Hi and Low and it still remains locked in the Low position. My truck has a 6" Pro-Comp suspension lift with custom gears in the rear. I also have a super-chips module installed and I have it programmed to 87 Octane and Gear ratio 4.53, I believe. I am not even sure what size gears I have in the rear because when I bought the truck the dealer did not know what size. When I programmed the super-chip I uploaded the 4.53 ratio. Would this have an effect on the gears or the four wheel drive problem?
Apr 12, 2021 at 12:14 PM (Merged)
GRANITES
In my 2004 F-150 you have to put the truck in neutral and then press the brake until you hear it disengage.
MECHMONSTER
Yes, he is correct. the vehicle must be completely stopped with the foot on the brake and the transmission in neutral (not in park) before you can disengage the 4x4 Low. This is not necessary to do if you are in 4x4 Hi. This is all described in your owners manual pg. 167.
ELREE
I had to use my 4x4 low today. Now it will not come out of four wheel drive. It has the switch type on the dash. The indicator light stays on for 4 low and stays in 4 low.
RACEFAN966
  • 5,029 POSTS
It sounds like the transfer case actuator is not working right here is the instructions so you can check it out or replace it.
If equipped with air suspension, turn air suspension OFF. Raise and support vehicle. Disconnect shift motor electrical connector on transfer case. Remove coil wire electrical spacer. Using electrical connector pin remover, remove coil wire and pin. Remove 4 shift motor attaching bolts, and remove shift motor. To install, reverse removal procedure.
WHIGHTOWER
  • 0 POST
I had this problem and had to replace the the actuator worked!
KEVIN SNOW
When you take the actuator off the transfer case how far do you turn the shaft that sticks out for the transfer case? It is stuck in 4 low. Do you turn the shaft half a turn to go to two wheel high or full turn? I want to know that way I will know if it going in to gear. I tried it once but when I started the motor and put into gear and the into park it started grinding. I do not think I turned the shift far enough.
STEVE W.
  • 15,158 POSTS
The problem with this is that without the actuator the case can move easily and drop into gear on its own which is likely what you had happen. There are no locking detents in the case like the manual cases used. The motor sets the position and holds the shift levers in place using the rotating cam in the case. Plus there is a clutch that gets a signal from the actuator as well and it will cause issues if you just remove the actuator. That is one of the problems with that system, the way it works it has to have the actuator or you will damage the case and its gearing.
