2004 Ford F150 engine fail safe mode
2004 FORD F-150
38,000 MILES • V8 • 2WD • AUTOMATIC
JDYNOMITE
The truck wont start it will turn over and try to start then just die. Im getting codes p606 and p1235 a pcm processor fault and a fuel pumpo control out of range. What can cause the fuel pump out of range code because ultimately i think thats whats causing the pcm error code. any help would be greatly appreciated. Thank you.
May 2, 2009 at 9:32 AM
