Engine Performance problem
2003 Ford F150 V8 Four Wheel Drive Automatic
03 F150 5.4 V8 When cruising in overdrive, if I start to go up hill, I give it gas and nothing happens. The engine has no power like its not getting gas. If I go full throttle it will downshift (I assume because of the kickdown) and actually slow down, but still dosn't seem to get gas. If I put it in neutral and turn the engine off and back on again, it's like it resets and everything works normal again. The problem is intermitent.
Thanks
Thanks
Jun 30, 2010 at 11:21 AM
