Engine Performance problem
2003 Ford F150 V8 Two Wheel Drive Automatic
My truck is hesitating after starting. I have found that it will start up, then will not keep a low idol until two or three starts. the truck starts fine. When I pull away after that it hesitates on low accelleration. this only happens for the first few minutes of running from stop to start (after several light signals. The truck has 140+ miles but is well maintained.
I have had the spark plugs, igintions coils, spark plus wires, and main computer checked. I also have rescently had the transmission fluid and gas filter changed. I am still having the problem. What should I do?
Mar 20, 2009 at 6:01 AM
