2002 Ford F150 Ticking Noise
2002 FORD F-150
12,900 MILES • 6 CYL • 2WD • MANUAL
ANDYSKI2
I recently replaced the clutch, Throw out bearing and pressure plate about 5000 miles ago. In the past few weeks I have noticed at idle when warm and the truck in neutral (clutch not depressed) that I can hear a ticking noise. Once I depress the clutch the noise goes away. It is also hard to get into first and I have to go from second to first or double clutch to keep from forcing it into gear. Condition comes and goes.
Now things get worse. While traveling I end up tossing the clutch. Ended up in a shop and when they pulled the tranny the center of the clutch had come apart. the shop replaces the clutch and the throw out bearing.
Truck travels fine for a couple hundred miles but now guess what. the ticking has started again. I also have to double clutch to get it in first or go from second to first to get it to slide into first. Condition comes and goes.
I am afraid I will damage a second clutch.
Any Thoughts
Mar 5, 2010 at 8:56 PM
