2002 Ford F150 abs
2002 FORD F-150
94,000 MILES • V8 • 2WD • AUTOMATIC
BIGAL2WIN
  • 7 POSTS
I was driving and lost power and saw that my abs light was on.drove a little more the light whent off.power was restored
what could this be
Feb 25, 2009 at 6:55 PM
KEVIN12881
  • 336 POSTS
there are numerous sensors that can cause the light to come on. this is not my area of expertise, but I have a haynes book and can help. the main reason I replyed is because you said the power came back! did you loose power brakes? I am no conserned if the ABS lights come on in my cars, ad in one it has been on and off for over a year, but I still have pwer brake just not anti lock. You will be fine if the ABS light is on and the brakes are not on anti lock, but loosing power brakes can be bad. usually the ABS light will flash when ther is a major problem. if they do pull over and get them fixed. if you wish to tackle this yourself i can offer what help i can. did you really loose power brakes?!
Feb 25, 2009 at 7:07 PM
2CARPRO JACK
  • CAR REPAIR CONTRIBUTOR
  • 11,533 POSTS
Lost power like the engine shut down?or lost electrical? I dont understand what you mean.If the ABS light was on, there should be a code stored in the computer to lead towards the cause of the light coming on
Feb 27, 2009 at 12:09 PM
BIGAL2WIN
  • 7 POSTS
no I just lost eng. power,still had brakes.
put code reader on showed no codes.
did find one bad fuse in the fuse box marked abs today.drove around the block, light not come on.I hope that was it,if not I will get back.
Feb 27, 2009 at 6:09 PM
2CARPRO JACK
  • 11,533 POSTS
What kind of condition is the batttery in? They can short internally causing intermittent stalling. Glad to hear you found a problem
Feb 27, 2009 at 8:08 PM
