2001 Ford F150 fuel pump
2001 FORD F-150
99,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIKE E. MARTINEZ
Truck will turn over but will NOT start
I acts as if it has run out of gas
I change the Fuel Filter and Fuel Pump Relay
When I had the fuel line off the filter on the tank side I try to start the engine to see if gas would flow
I try several times but no gas came out
Is this a clear indication that the Fuel Pump is bad?
Thanks, Mike
Dec 3, 2009 at 8:41 AM
