2001 Ford F150 Engine Hesitation/Missing
2001 FORD F-150
80,500 MILES • 6 CYL • 2WD • AUTOMATIC
MATTKB
A while back my truck was using a lot of gas so I changed the EGR sensor, and that fixed the problem, but ever since then my truck has been hesitating or missing. It doesn't do it all the time, and it seems to be a lot worse when it gets wet. I have put Winns Shudder/Guard in the transmission. I have changed the fluid and filter in the transmission. I have changed the rear end grease and greased the plugs to the fuse box. I called the Ford dealer and they told me that it could be a shattered torque converter or the fuel filter. I'm going to change the fuel filter soon to see if that helps, but I am at a loss for what else to do. I would appreciate any advice you could offer. Thanks.
Mar 9, 2008 at 1:34 PM
