PROBLEM:
PCM CODE PO304, 1998 FORD F-150 4.6L VIN CODE “w†95,000 MILES.
ENGINE ALWAYS STARTS NORMALLY HOT OR COLD. IDLE IS GOOD WITH A SLIGHT MISS ONLY SOMETIMES WHEN WARM. IDLE RPM IS NORMAL IN NEUTRAL AND IN GEAR, WITH AUTOMATIC XMSN. (4R70W)
ENGINE RUNS GOOD WHEN COLD, MISS ON #4 CYL ONLY WHEN ENGINE IS WARMED UP, AT LOW RPM (1700+-) IN TOP GEAR ON SLIGHT LOAD AND MINIMUM THROTTLE (UP SLIGHT GRADE) DEFINITE MISS ONLY UNDER THESE CONDITIONS+ MIL LIGHT ON.
ENGINE RUNS STRONG AND WELL UNDER HEAVY THROTTLE IN 1-2-3-4th GEAR HOT OR COLD. UNABLE TO CHECK TOP GEAR HIGHER SPEEDS OR HIGH SPEED STEADY STATE DUE TO SNOW/ICE ON ROADS.
HAVE CHANGED PLUGS AND WIRES, BOTH COIL PACKS, AND ALL EIGHT FUEL INJECTORS. FUEL FILTER WAS CHANGED 5,000 MILES AGO. NO VISIBLE HEATER H2O LEAK AROUND #4 CYL AREA. ALL OTHER DASH GUAGES ARE NORMAL.
Nov 27, 2008 at 10:13 PM
