2004 Acura MDX it pulled slightly left
2004 ACURA MDX
46,000 MILES • 6 CYL • 2WD • AUTOMATIC
2CP-ARCHIVES
  • 4,540 POSTS
2004 Acura MDX 46,000 miles. V6. When I bought this vehicle used, it pulled slightly left and we thought it was an alignment issue. However, after the alignment, there was no improvement. Now the dealer says there must be a 'radial pull' in one of the tires. What does this mean? What do you recommend I do? How much should it cost to repair? I'll be happy to make a donation if you can give me some guidance.
Oct 9, 2010 at 12:39 AM
2CP-ARCHIVES
  • 4,540 POSTS
Have you rotated the tires since you bought the vehicle? I recommend rotating the tires before replacing of tires. Another line of thinking is that a brake on that side could be hanging a bit.
Oct 9, 2010 at 12:42 AM
