Hi,my problem is with the 4R70W trans.This trans was having a problem with the last shift as you accelerate it would shift thru the gears ok then at the last shift it would rev like it was in neutral and go into the last shift hard. The trans was rebuilt by a quality shop and was ok for about 20,000 miles started having the same issue. this time if you toggle the o/d switch on the shifter the trans will downshift ok but when o/d is put back on the engine will for a few seconds then will shift hard into o/d. This happens every time at about 40-45 mph. The man at the trans shop is stumped. Help please!!
Jan 23, 2010 at 4:25 PM
