1999 Ford F150 Two Wheel Drive What is the function of the cam sensor?
Mar 5, 2009 at 5:40 PM
RACEFAN966
CAR REPAIR CONTRIBUTOR
What it is for is to replace a distributor. It keeps track of the cam so that the computer can use the signal coming from it to fire the right cylinder at the right time. Some use just a cam sensor to this some use a crank sensor some use both.
Aug 21, 2020 at 5:51 PM
GTRANTUNEZ
MEMBER
1 POST
I can not find my Camshaft Positon Sensor location on my ford f-150 truck do you know where its located?
Aug 21, 2020 at 5:54 PM
(Merged)
BLUELIGHTNIN6
it will be on the front of the engine, post your engine size and I will give exact diagram for you
(Merged)
The Camshaft Position Sensor is located in front of the engine.
(Merged)
MANDO-76
MEMBER
Help! I have a 97' F-150,4.2L V-6.Engine light came on. So I pluged in a code reader,and it gave me two codes,P0340 & P0430. For P0430 I changed the O2 sensor and the code was gone.Now for the last code I changed the Camshaft Position Sensor,But the light wont go away.Now when I changed the Cam. sensor I didn't secronized the shaft.Could that be why the light is still on?
Aug 21, 2020 at 5:55 PM
(Merged)
SERVICE WRITER
Yes, The shaft itself very well may be bad. The sell new ones at NAPA with the sensor less than $100.
(Merged)
MANDO-76
MEMBER
I thought so...Thank you.
(Merged)
ALMILL3
MEMBER
I am getting trouble code P0340 ( Camshaft Position Sensor A - Bank 1 Circuit Malfunction) and I can't seem to find it for replacement. Does anyone know where I can find it and how hard it is to change out? Or do you have any suggestions of why else this code would be showing up if it isn't the sensor itself? Thanks.
(Merged)
SERVICE WRITER
Your going to likley need the shaft that is right underneath it as well. They are available aftermarket that includes the synchronizer shaft and the sensor. Napa carries it.
(Merged)
ALMILL3
MEMBER
If it isn't too difficult, I might end up changing out both the shaft and the CPS but I am having a hard time locating it. I would think that it would be located on top of the timing cover but I couldn't find it. Any help?
(Merged)
SERVICE WRITER
If I have time later tonite, I'll upload the the R&R procedure, you don't want to do this wrong.
I have to answer donor posts first, if there is time tonite, I'll post yours, gotta get to work to make a living.
(Merged)
KRISTY MAIRE PENTON
MEMBER
I also have a 97 F150 4.2L I found the cam position sensor by taking off the air intake hose from the throttle, remove upper radiator hose and two y heater hoses and maybe a few bolts I don't see where the bolts need to come off yet. My question is to prevent antifreeze leakage or waste can I get to it easier from under my truck?
(Merged)
KRISTY MAIRE PENTON
MEMBER
Also just to replace the sensor not the synchronizer you just unscrew it and put on the new one otherwise you need a special tool and technique for the synchronizer
(Merged)
Thanks for the input, to stop the coolant from draining all over use a bucket to drain into once the radiator drain plug is loosened. Did you need more info? we are happy to help.
(Merged)
KRISTY MAIRE PENTON
MEMBER
Is there a special technique or tricks to changing the fuel filter in one of these trucks?
(Merged)
UCBEARCAT45157
MEMBER
1 POST
MY CHECK ENGINE LIGHT CAME ON THIS MORNING. I HAD IT CHECKED AND IT SAID IT WAS A BAD CAMSHAFT POSITION CENSOR.FIRST WHERE IS IT LOCATED AND HOW DO I GO ABOUT REPAIRING IT MYSELF.IS THEIR A WEBSITE OR SOMEWHERE I CAN GO TO I CAN PRINT OUT THAT WILL SHOW ME THANKS RON
(Merged)
BLUELIGHTNIN6
What size engine? 4.2L , 4.6L , 5.4L ?
(Merged)
Not really but you will need to start a new question this thread is for a camshaft sensor.
Please post your new question here, you must be logged in.
