2CarPros - Car Questions & Answers
1997 Ford F-150 Repair Question
Topics covered: Starter, Battery, Engine.
Asked on May 10, 2006
1997 Ford F-150XLT
My battery will not stay charged! I have changed the altinator 3 times now finally having a good one! Bought a new battery and it still will not stay charged, but when I am going down the road and the battery goes dead my truck keeps running until i kill it! And i have checked all fuses in my truck and all wires, but still havent found the problem!
Avatar Asked by madman2008
Answer
Replied on May 10, 2006
I think you have a ground problem. clean all ground connections from the battery to the engine, battery to the frame and engiine to the fire wall. Shiny clean
Do the same with the + side. make sure the battery is disconnected when you do. Also the red wire from the battery to the under hood connector. Let me know
Tiny Answered by losone
7 questions asked
ALL OF THE WIRES ARE CLEAN DO U THINK IT COULD BE MY STARTER BECAUSE IT TRIES TO GIVE ME TROUBLE STARTING
Tiny Response from madman2008
1 question asked
Replied on May 11, 2006
Perhaps. I would replace the starter solonoid first. It is located on the fender well. Ford starters are a high failure item. Let me know
7 questions asked
I HAVE CHANGE THAT TO SO CAN IT BE MY STARTER IF SO LET ME KNOW
1 question asked
It could be the starter. Please don't put on a "Zone" starter as they often cause grief.
7 questions asked
a autozone starter
1 question asked
hopefully it works. The last Ford Zone starter I used came apart and destroyed the flywheel and front pump on the transmission. Turns out it was a used starter that was cleaned and painted and reboxed and sold.
Maybe your luck will be better
7 questions asked
how many bolts is holding the starter on bcause i took out three out all really i dont see know more around it could be holding it
1 question asked
Replied on May 12, 2006
Unless Ford has changed their design, it has 3 bolts. It looks like the pry and wiggle trick. Good luck
7 questions asked
well hao do i get it off
1 question asked
