1995 Ford F150 Fuel system
1995 FORD F-150
179,453 MILES • 6 CYL • 2WD • MANUAL
TOMWILSON22
Howdy, ive been having some problems with my truck. At first the fuel pump went out in the front tank then in the back, so i took the back tank off to find a hole in the tank so i left the tank off and i just got the front tank know i took the spiltter off so that the gas wouldnt go to the back lines i also changed the fuel filter and changed the spark plugs and its still not starting? i cant find the fuel shut off switch so that i can reset it do you think that by reseting it this would fix my problem and my truck run again and also do you know where the shut off switch is i looked under the carpet behind the glovebox and still nothing. Thank you very much for taking the time to anwser my question Thanks Thomas Wilson
Jan 24, 2009 at 8:33 PM
