My Truck has stalled a couple of times this week when taking off from a stop sign. It will not start back up. I have to let it sit for about 5-10 minutes before it will start again. I had the battery and altenator checked and they are all right. I replaced the fuel filter, air filter, plugs and plug wires. When taking off (without pushing down on the gas pedal) it will move and when I push down on the gas it seems to flood out?? I am hoping it is an easy fix, because I am not real mechanically inclined. I can the the basics. Also, after the truck stalled and when I got it going again the check engine light came on for about 3-5 seconds. I am the original owner and the check engine light has never came on before. Thanks
Mar 1, 2008 at 6:35 AM
