firing order
1997 FORD F-150
142,070 MILES • 6 CYL • 2WD • AUTOMATIC
JEFFJ
  • 36 POSTS
My truck has a 4.2l. What is the spark plug wires routing? i.e from coil on top of tunnel ram to plugs.
Mar 11, 2011 at 4:47 PM
DOCFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 18,828 POSTS
Here is the engine spark plug firing order. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Cheers
Mar 11, 2011 at 5:00 PM
TXWILDFLOWER281
Electrical problem
1996 Ford F150 V8 Two Wheel Drive Automatic
What is the Fifing order on this truck?
Feb 8, 2021 at 12:44 PM (Merged)
2CARPRO JACK
  • 11,533 POSTS
5.0 liter
https://images.2carpros.com/forum/automotive_pictures/1639_ford_50_1.jpg
5.8 liter
https://images.2carpros.com/forum/automotive_pictures/1639_ford_58_1.jpg
WALKER2980
i have miss placed my plug wires on my distributor and can't get them in the right order. Can't seem to find a diagram for it...HELP!
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_49_firing_order_1.jpg
Hello, 4.9 vin Y Verify TDC for #1 is correct on the distributor
VEGAJERRY
what is the firing order?
BLUELIGHTNIN6
  • 16,542 POSTS
4.9L engine Firing order: 1-5-3-6-2-4 Distributor rotation: Clockwise
https://images.2carpros.com/forum/automotive_pictures/261618_0900c152801cd424_1.jpg
Let me know if your engine is different than a 4.9L engine.. Thanks for using 2CarPros.com!
MLEEBARNES
My F150 4.9L engine has a different firing ofrder. Mine is similar to the 4.9L tempo listed on your site.
I attached all the info from the manual on timing and firing order just for your reference and others in the future. Thanks
JOELDENNIS7
I have a Ford F150 with a 5.0L mustang Engine. What would be the firing order for that. I
Feb 8, 2021 at 12:45 PM (Merged)
Here is the engine firing order. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Cheers
LOU SPINNER
Do not know how to set timing.
Good afternoon.
All the information is below.
Firing order
1-5-3-6-2-4
Cap location for wires attached.
Ignition timing
INITIAL TIMING
1. Place transmission in NEUTRAL (M/T) or PARK (A/T) with A/C and heater in OFF position.
2. Connect an inductive timing light.
3. Disconnect the single wire in-line Spark Output (SPOUT) connector or remove the shorting bar from the double wire SPOUT connector.
4. Start engine and allow to reach operating temperature. With engine at timing rpm, check or adjust initial timing to specification.
NOTE: To set timing correctly, a remote starter should not be used. Use the ignition key only to start the vehicle. Disconnecting the start wire at the starter relay will cause Ignition Control Module (ICM) to revert to start mode timing after the vehicle is started. Reconnecting the start wire after the vehicle is running will not correct the timing.
5. Reconnect single wire in-line spout connector or reinstall the shorting bar on the double wire spout connector. Check timing advance to verify distributor is advancing beyond the initial setting.
6. Remove test instruments.
Ignition timing
Base Timing .................... 10° BTDC
AJSEXTON
I need to know the firing order on the motor and the to install the oil rings into my truck ?
BMRFIXIT
  • 19,053 POSTS
V8 5.0L
https://images.2carpros.com/forum/automotive_pictures/99387_50_and_75_1.jpg
5.8L
https://images.2carpros.com/forum/automotive_pictures/99387_58_l_1.jpg
TD MCLEAN
the firing order and spark plug wire order for a 302 efi fuel inj engine if so can i get a picture or a diagram please asap.
https://images.2carpros.com/forum/automotive_pictures/12900_fo_9.gif
Firing Order 1-5-4-2-6-3-7-8 https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
PUFFYSTEVEO
Engine Performance problem
1979 Ford F150 V8 Two Wheel Drive Automatic
I need to know what the firing order is and a picture of it. I replaced the cap and rotor and boy does the truck run bad, backfires
There you go
https://images.2carpros.com/forum/automotive_pictures/12900_58912497_1.jpg
NANCY DEITZ
I need just to look at the firing order for a 1979 f 100 truck ,300-6 cylinder (anything else)
NANCY DEITZ
I need just to look at the firing order for a 1979 f 100 truck ,300-6 cylinder (not anything else) please
BOBMONTANA
my problem started after replacing the distributor cap and rotor because of a rough idle .now the engine misses real bad and exaust is black and smels like it is running too rich.adjusting the timming did not help and the spark plug keep sooting up.I replaced the plugs plug wires distributor cap and rotor,new fuel filter.and the carburator has no fuel mixture adjustment.what else could be the problem?sure could us some help...thanks..Bob
ROB2008
  • 258 POSTS
Make sure you have the firing order right and rotor is in the right position . To make sure you have the rotor in the right position find the ,"tdc" To do that remove 1 spark plug, put your finger over the hole and have someone move the crankshaft by hand (t-bar and a socket on the end of the crank pulley) turn the crank untill you feel air push your finger from the hole. When it does watch the crankpulley and put it on 0 degress you are now top dead center on number one. this should be the firing order for your vehical
https://images.2carpros.com/forum/automotive_pictures/181498_ford_firing_order_1.jpg
I read some where that Rough idle, that cannot be corrected by normal service procedures on 1977 and later models, may be cause by leakage between the EGR valve body and diaphragm. To determine if this is the cause. Hope this helps ya.
