1994 Ford F150 Clutch pedal is to the floor w/o any pressur
1994 FORD F-150
LEIF.THE.DRUMMER
Transmission problem
1994 Ford F150 6 cyl Two Wheel Drive Manual 140XXX miles
My 1994 F150 was running fine until the weather turned cold. One morning I was attempting to leave work and my clutch pedal lost pressure and went straight to the floor. There are no leaks that I can find, but it still wont build pressure. I asked a couple of people and some said that its the master slave, my uncle who is a trusted mechanic said that it is more than likely the master cylinder, but both aren't cheap and the slave definitely isn't easy. Just wanted to know what you all thought!!
Mar 13, 2010 at 9:21 PM
