1993 Ford F150 STALLS,FUEL PUMP RUNS EVEN IF ENGINE IS NOT
1993 FORD F-150
240,000 MILES • 4 CYL • 2WD • AUTOMATIC
JIM286099
i am having a problem of my truck running fine for a few days then it takes a spell that it will not run at all.
the check engine ligfht will come on and the truck will act as if it is flooding, i also noticed that when it does this i can not shift it from overdrive.
i have replaced,plugs,plugwires,relays and even had a new gastank put on due to some leakage.
i have also noticed that there is the smell of unburned gas coming from tailpipe.
sometimes it will be intermidite and you can hear a clicking coming from under the hood on the drivers side. any ideas?
Sep 11, 2010 at 12:45 PM
