Can you actually hear the pump running? You should just be able to hear it, especially with the truck off and the key on.
It's possible that the pump could be wired backwards, but in my experience it would just short it out. It wouldn't run in reverse. Maybe someone else here at the forums could tell you for sure if that's true or not. Most likely the pump won't run at all if it was wired backwards.
Have you checked for any blockage in the line?
The fuel pressure regulator is located on the rear driver's side of the fuel rail. Pull the vacuum line off the top, and if it smells of gas, then the diagphram inside has ruptured. That's about the only way you can check it without the truck running steadily.
Jan 24, 2008 at 10:37 AM
