1992 Ford F150 steering coupler
1992 FORD F-150
151,000 MILES • 6 CYL • 2WD • AUTOMATIC
BASSFISHER23
How to remove the steering coupler from the column. Theres no bolts or nuts just four metal circles top bottom left and right with a rubber piece in between One side of the circle is flat other is circle withing a cirlce and i couldnt use an align wrench. Is there any special tools i need to remove this. the pinch bolt broke in the coupler so i have to take the gear box out with it. Didnt have enough room in the engine compartment to drill it out
got it off thanks
Mar 14, 2009 at 2:41 PM
