1991 Ford F150 Fuel pump
1991 FORD F-150
105,000 MILES • 6 CYL • 2WD • MANUAL
SCARROLL4406382
Truck won't start, when key is turned too on position the fuel pump runs the whole time key is on before it would shut off after a few seconds, plugs are new, but when I checked for spark they had a lot of carbon or soot on them, fuel filter new, pulled fuel line after filter turned on key there seemed like strong flow of fuel, behind intake manifold there is small fitting that looks like valve stem attached to fuel line, pushed it in fuel sprayed out under pressure
May 3, 2009 at 8:55 PM
