THE KEY SWITCH ACTIVATES THE GAUGES AND FUEL PUMP, BUT DOES NOT ENGAGE THE STARTER. THERE IS NO RESISTANCE TO THE KEY. WHERE IS THE SWITCH LOCATED IN THIS MODEL VEHICLE? I WAS TOLD THAT THE SWITCH/COMMUTATEUR/INTERUPTOR (DISCRIPTION ON NEW SWITCH BOX) IS THE PROBLEM. CAN YOU HELP? IF YOU HAVE A DIAGRAM THAT WOULD HELP. ANY HELP WILL BE APPRECIATED.
THANK YOU
THANK YOU
Jun 22, 2010 at 7:55 AM
