1988 Ford F150 Can't get any spark
1988 FORD F-150
30,000 MILES • 6 CYL • 2WD • AUTOMATIC
YACAPH
1988 ford F150, 4.9 liter 6 cyclinder, manual trans.
I'm not getting any spark at the spark plugs or from the coil (except for an occassional spark where the key is turned off). I've replaced the coil, distributor, and ignition module. I have 12 volts at the coil and module when the key is in the on and start positions. I've check for continuity on all of the wires except for the 3 wires from the module to the control units.
I don't know what else to check or look for. Would the control computer prevent the system from firing?
Any help woudl be greatly appreciated.
Jan 12, 2008 at 2:43 PM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
Make sure your tach wire isnt grounding! Check fuses in the power distrbution center under the hood, and all ecm fuses in car and under the hood.
Jan 12, 2008 at 4:27 PM
