1987 Ford F150 Won't Start?
1987 FORD F-150
180,000 MILES • V8 • 4WD • AUTOMATIC
MADEZ
It ran about 1/2 an hour, pulled up to a stop sign and died. Haven't been able to start it since. Won't jump. It doesn't get fuel to the filter or line. I've replaced both the filter and the fuel pump. It is getting a spark and cranking, but won't run. Checked the fuel shut off valve by the firewall and the fuses. All ok. Sprayed ether in throttle body. Nothing. Has spark on number 1 cylinder. Had been running fine up to this point. Has plenty of fuel. Any ideas?
Feb 1, 2009 at 7:35 PM
