1987 Ford F150 no giddy-up
1987 FORD F-150
HEDP203
Engine Mechanical problem
1987 Ford F150 V8 Two Wheel Drive Automatic
my engine runs a little rough at idle but not to bad, I have replaced the entire fuel system, new tank, sending unit, high pressure pump, filter, purged lines, and replaced injectors. (due to very old gas) when i put the truck in drive or reverse it stalls or act like its running on 2 cylinders. plugs wires and distributor all new as well. I have 42psi fuel pressure. No vacuum leaks i can find, what else should i look for?
thanks,
Feb 26, 2010 at 5:01 PM
