Computer problem
1987 Ford F150 Two Wheel Drive Automatic 145000 miles
Was driving along and hit a pot hole , the engine stopped. The engine won't start now. The fuel pump is running properly, there is pressure at the rail. An ignition tester tells me I have spark at the plugs.The engine turns over normally.I have dumped in gas line anti freeze in case it is water. The engine doesn't even try to fire. Its not the inertia switch. If it was low fuel pressure wouldn't the engine try to fire? I operated thre bleed on the rail and got fuel spray. The distributor is clamped down tight.
The bump has me perplexed, please help
John MacDonald
John MacDonald
Mar 21, 2008 at 12:41 PM
