1984 Ford F150 fuel filter
1984 FORD F-150
100,000 MILES • V8 • 2WD • MANUAL
RAINBOW1
what is the process to remove and replace the fuel filter. It leaks gas when running, does not leak when the engine is off
Feb 13, 2008 at 9:26 AM
BLACKOP555
  • CAR REPAIR CONTRIBUTOR
  • 10,386 POSTS
loosen anytype of device to hold the fuel filter then twist it to break the ends free, then if you have hairpin type connectors just stick a screwdriver under the top and twist them to break them free.
if you have spring lock coupling or duckbill connectors there is a special part sold at auto part stores to disconnect them.
Mar 14, 2008 at 12:56 PM
