1959 Ford F150 55 International pickup
1959 FORD F-150
50,000 MILES • 6 CYL • 2WD • MANUAL
HENDRICKSON
Hi! Info entered above is not correct because all the marked fields are not for my truck. Have a R 100. Restoring. All lights seem to work fine except the Stop lights. Put in a new brake switch and hooked up the wire too it and nothing. So I installed a new wire to back of truck from brake switch and hooked up to the tail lights. Brake lights worked but also the front signals lit up at same time. If I scratch my head any more I will be removing skin. Hope you can help me. John Hendrickson (stumped) Also the turn signals do flash pretty fast.
Mar 25, 2008 at 11:38 PM
