1999 Ford Explorer Repair Question
Topics covered: Brake pads, Wheel.
Asked on June 23, 2006
Brakes on 1999 Explorer XLT 4WD 130K Mi.
I need to replace the brake pads on all four wheels, and the front passenger rotor needs replacement as well.
Do the rotors need to be replaced in pairs (front & rear) the way the pads do?
Answer
Replied on June 23, 2006
Personally I would replace both rotors, along with the new pads, should give you nice smooth braking,, rotors are relatively cheap, buy the cheap ones, you'll notice no difference from the more expensive, I don't care what others say,, you'll have a bit more $$$ in your pocket to put toward your next fill-up..
