2004 Ford Explorer Repair Question
Topics covered: Panel, All wheel drive, Wheel.
Asked on January 3, 2008
Keyless entry
2004 Ford Explorer 6 cyl All Wheel Drive Automatic 60000 miles
I have a 2004 Ford explorer. I need the factory set code to reset my personal code for the keyless entry. The code is marked on the "computer module" Where is the computer module located?
Answer
Replied on February 8, 2008
I just bought an 04 same problem. The computer module is behind the panel in the back seat. Not the 3rd row seats. Passenger side. If you were sitting in this spot it would be about shoulder height. Pop of the top panel carefully than pull gently ouy on the bottom panel. With a flashlight you will see the sticker on the module. I was real scared at first that I might break something but it was real easy. Took 5 minutes. I got my information from serious explorations and It was right on Good luck
