1997 Ford Explorer FAILED INSPECTION FOR MIL FAILURE 801
1997 FORD EXPLORER
160,000 MILES • V8 • 4WD • AUTOMATIC
TFC35
  • 7 POSTS
Went for inspection and they failed due to check engine light does not light up when the switch is turned on prior to starting the car.
Is it just the check engine light indicator bulb or a fuse. Where do we start for malfunction Indicator blinked Code 801 and failed inspection for 1997 ford explorer. Thanks for all the help. Still working on the Neon!!
Jul 5, 2008 at 11:04 AM
