transmission seal?
2002 FORD EXPLORER
NESTO
I bought it from the dealer , at the time thye told me it is a sealed transmission and i dont need to serviced it for about 100,000. due to the factory sealed transmission.Almost 2 years later and still owing $8,000 dollars it looks like my transmission is dying. the question is this under some sort of warranty from Ford cause my warranty from the dealer expired, Can I do it myself?
Jun 26, 2007 at 11:09 AM
2CARPRO JACK
  • CAR REPAIR CONTRIBUTOR
  • 11,533 POSTS
Since you are out of your powertrain warranty, the best you could do is plead your case that the trans is not serviceable, and ask why they would put such a thing on the road.It isnt like their auto trans's are known for durability or longevity, I have seen many of them go out sooner than yours, even with proper service.
This video will help you replace the front seal transmission removal
https://youtu.be/3vJAojsrfuU
Jun 28, 2007 at 8:14 AM
GOODGIRL9
my transmission seemed to be hesitent when shifting. the o/d light was blinking. so the next day i took it in to get fluid checked. while it was in the bay of the service center they said the front seal blew. i think they over filled the tranny fluid. what else would cause this to happen. mind you i took my explorer in to the shop within 24 hours of noticing the problem. why would the seal just all of a sudden blow while it was just sitting there with the engine running
Jun 28, 2020 at 12:33 PM (Merged)
  • 54,350 POSTS
Yep, that is an amazing coincidence but it does happen, the front seal would not blow if they overfilled it though.
Please let us know what you find so it will help others.
Best, Ken
RMOORE09
  • 132 POSTS
Hello, I had an inspection today and here are the results
Brake Master Cylinder Leaking
Oil Valve cover and oil pan gaskets worn
All four shocks worn
Door Lock Actuator bad in two doors
Power Steering pump going out
AC and Alternator Bearings going
Rear Transmission Seal Leaking
Transmission slips into neutral sometimes between 1st and 2nd happens everytime you run ac.
Crank Seal Leaking
Is it just time to replace the entire car? I need an opinion because its got 211000 miles and is this stuff worth fixing?
CJ MEDEVAC
  • 11,004 POSTS
transmission problem could be simple.....or major (i know little about the newer computer stuff)
excluding the tranny--if you diy the rest of the issues-----you could probably do them for less than $500
JAKE852000
I am buying a 96 explorer from a friend he had to replace the flywheel and while in there replaced a leaking front tranny seal however the seal blew out I have since replaced it and am wondering what would make the seal blow out and if i should be worried about it recurring
  • 110,190 POSTS
Chances are the torque converter is worn. The converter slips through the seal. If it is worn, it will cut the seal.
STACEYMARIE
Sorry I can't be of help to what causes the seal failure. But I would like to know how you went about fixing the seal the first time. Did you do it yourself or have a mechanic do it? Also what was the cost? I have a 1996 ford explorer limited addition with a tranny fluid leak. After having a friend look at it he suggest it's the front seal. I just had this truck inspected and engine is strong, just wondering if it's worth fixing or time for a new vehicle.
JWBRYSON
Brakes problem
1996 Ford Explorer 6 cyl Two Wheel Drive Automatic 170K miles
What is a resonable estimate for replacing front and rear brakes including pads, rotors; repairing two oil seal leaks and one trans. seal leak?
Jun 28, 2020 at 12:34 PM (Merged)
  • 110,190 POSTS
Can you tell me what seals are being replaced?
RICKMAR
  • 170 POSTS
[quote:a291198c32="JWBRYSON"]Brakes problem
What is a resonable estimate for replacing front and rear brakes including pads, rotors; repairing two oil seal leaks and one trans. seal leak?[/quote:a291198c32]
The pads "all four" wheels will be $50 - $60 their cost.
The rotors "all four" wheels will be $100- $120 their cost
That pads would be around $100 your cost.
The rotors would be around $180 your cost
They will probably charge you $280
for all pads and rotors
Labor some where around $200
So just your brakes alone "all four wheels" complete pads,rotors,labor will cost you $480 in that vicinity (reasonable)
I do not know what 2 oil seals are leaking so I can not "guesstimate" that.
I do not know what 1 seal in you trans is leaking so I can not "guesstimate that either.
Let me know what the "seals" needed are...all 3 of them and I could give you a reasonable cost to expect.
Rick
SNIPER1668
  • 5 POSTS
i recently changed the pitman arm seal on my steering gear box due to it was leaking,,the installation consists of a flat washer,,seal kit,,dust cover,,washer and snap ring....the problem is i installed the first washer,seal and dust cover i had no room for the second washer and snap ring i thought i installed them unevenly so i pulled them out and bought a new kit and reinstalled ,,,,,same problem,,,this is the right seal for my truck,,,i just installed the snap ring and left out the last washer there are no leaks and everythings ok but i dont want the seal to blow out on me while im driving,,
and thoughts
  • 110,190 POSTS
My primary concern is the last washer distributes pressure on the seal. Without it, the seal could leak again. Are you sure there was no way to get it into place?
SNIPER1668
  • 5 POSTS
i put a socket around each part and tapped into place everything is set as far as they will go,,i looked at several diagrams online and none show any washers just the seal and dust cover,,i thought the washer actually created the seal,,maybe i should remove the top washer not the bottom
SNIPER1668
  • 5 POSTS
were can i find a exploded view of the pump seal,,1993 ford explorer,,,maybe the design has changed all seals im finding dont have washers just dust cover and than snap ring ??
  • 110,190 POSTS
Here is what I was able to find. Let me know if it helps.
https://images.2carpros.com/forum/automotive_pictures/249084_5_65.jpg
KYLE_ABB
I have a 93 ford explorer and my front transmission seal went out but to drop it out to replce the seal do i have to remove the exhoust, i dont want to have to replace it, most of it is rusted together.
  • 110,190 POSTS
I hate to say it, but yes. Otherwise, you won't have enough room to remove the trans unless you are able to get it up and over the Y pipe.
