Location of the cabin filter
2003 FORD EXPEDITION
CABINDARITMO
V8 two wheel drive automatic.
I am trying to locate the cabin filter for the air conditioner of my SUV.
I would appreciate your help.
Cabinda Ritmo
Jan 30, 2009 at 6:45 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,350 POSTS
Hey Cabindaritmo,
from the book:
Note: The air distribution system of this vehicle cannot be equipped with a cabin air filter.
Cabin air filter is available as an optional dealer-installed kit. Cabin air filter installation instructions are included with the kit. If a filter is already installed, it is located under the right side of the instrument panel in the HVAC housing. Trim panel may have to be removed to gain access to filter
Remove attaching screws for the cover and pull the tabs on the filter out. Put it back in making sure the tabs face the filter cover. Reassemble and you're done. All expeditions don't have cabin air filter. It should say filter on the cover.
Here is a guide that may help you see what you are in for when replacement the cabin air filter:
https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter
Please let us know happens so it will help others.
Best, Ken
Dec 1, 2016 at 5:15 PM
KURTCOOPER
Ken, how do you know if you have the optional dealer kit? I have the 2003 Expedition was not from a dealer, and I do no know if I have a filter to replace or not,
Let alone how to gain access to that.
I took a look the other day, it is so tight and some screws hard to get to.
The reason I was looking around down there, is my fan makes noise when I have the AC on and hit rough road or a hole etc., on the road. It makes a loud noise then It goes away. I wanted to open and see if there are some loose screws holding that fan, but it seems a tough job to get in there.
Any help will be highly appreciated.
Jul 27, 2018 at 3:26 PM
STEVE W.
  • 15,158 POSTS
The 2003 did not have an HVAC box that had a factory filter. There is a kit that could be installed on the first generation trucks up to 2002. When Ford did the redesign for the 2003 the new HVAC box the blower motor was relocated and there is no provision in the new system for a filter.
The attached is the filter kit instruction, for it you remove the trim panel under the glove box and the blower motor is there. The filter is located next to it.
On the 2003 the blower motor is hidden behind the passenger side kick panel trim cover.
If you have blower noise it is likely that something fell into the system.
Jul 28, 2018 at 8:20 PM
KURTCOOPER
Thanks a lot Steve,
I have got the blower out yesterday after a good struggle getting it out. When I looked there was nothing should not be there, clean and clear from any strange objects. But when I move the fan by hand, it was turning freely, but with a little sounds, I believe was not a smooth bearing sound. It could be the reason. which I need to replace the hole blower as ASEMASTER6371 suggested on my question about that.
I appreciate your time and help.
Jul 29, 2018 at 12:34 AM
STEVE W.
  • 15,158 POSTS
Yeah, the blower should turn smooth and quiet. If it is noisy it is likely from dust/moisture getting to the bearings. I have taken them apart and lubricated them before, but that is not something I recommend as some are not really "user friendly" to work on.
Glad to hear you have it well in hand. Thank you for using 2CarPros.com.
Jul 29, 2018 at 2:38 AM
EDALLEN40
Where and how do I change a cabin filter for the 2002 Eddie Bauer Expedition? I cannot locate an answer online to this problem, some say it does not have it some claim that there is a location that has an inch slot with two plastic hex shape nut but it could not remove it without tearing. Any suggestions?
Aug 6, 2018 at 11:55 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
The cabin filter was an option in these vehicles. If your vehicle has it, the filter will be located on the passenger side under the dash. Below you will find a guide for replacing the filter as well as a diagram of the location
A cabin air filter is available as a dealer-installed accessory for the air distribution system of this vehicle. Instructions for installing and servicing the cabin air filter are included with the filter when purchased
2CP-ARCHIVES
  • 4,540 POSTS
Hello!
Will you please tell me where is located the air cabin filter on a 2002 ford expedition XLT with a 5.4 engine?
IMPALASS
  • 3,112 POSTS
Hello! here you go
JAMES MCDONOUGH
hello, I have a 2003 Ford Expedition.It is the Eddie Bower eddition. The motor is the 5.4 Trinton.I have looked at other web sites and they have stated that it is located on the firewall wall on the left side as I am looking at the vehicle. not there. Another site stated "under the dash". O K where. I would appreciate your help with this. Thank You Jim.
Aug 6, 2018 at 11:56 AM (Merged)
KHLOW2008
  • 41,814 POSTS
CABIN AIR FILTER
Cabin air filter is available as an optional dealer-installed kit. Cabin air filter installation instructions are included with the kit. If a filter is already installed, it is located under the right side of the instrument panel in the HVAC housing. Trim panel may have to be removed to gain access to filter. See Fig. 1.
JOHNSTEINBACH
Where is the location of the cabin filter in a 2003 Ford Expedition?
Aug 6, 2018 at 11:57 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
This car does not have a cabin filter.
"NOTE: The air distribution system of this vehicle cannot be equipped with a cabin air filter."
I have heard some dealers installing a cabin air filter is available as an optional dealer installed kit it is located under right side of the instrument panel in the HVAC housing.
JACK4389
I’m trying to locate cabin air filter but I can’t find it.
Mar 23, 2019 at 4:09 PM (Merged)
JOETECHPRO
  • 705 POSTS
Hey JACK4389,
From what i can see there is no cabin air filter fitted to your vehicle.
I would call a Ford main dealer, they will quickly be able to tell you from your VIN whether there is one fitted as standard to your vehicle.
Regards, Joe
