Firing order?
2001 FORD ESCORT
MARKMTBLDY
are the numbers on the coil pack as in number one goes to number one cyl and so on
Aug 25, 2009 at 7:58 PM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_481.jpg
Aug 26, 2009 at 5:11 AM
ROOFMANN
I am helping a friend work on his 98 Escort ZX2 with the DOHC engine. He had removed all spark plug wires to do a tune up and now I cannot get the wires back on in the proper order.
I know that the firing order for this motor is 1,3,4,2, but according to the manual the #1 position on the distributor is in the lower right corner. The problem that I am running in to is this:
The longest plug wire will not stretch from the #1 position on the distributor to the number one plug.
Can someone tell me if I am incorrect on the #1 distributor position.
Also, is the firing order on the distibutor clockwise or counterclockwise?
Oct 7, 2020 at 11:36 AM (Merged)
2CARPRO JACK
  • 11,533 POSTS
According to my software, that is a distributorless ignition. 98 ZX2 DOHC. Here is a pic, if it doesnt help get back to me witht heexact production date off the door sticker, drivers side.
https://images.2carpros.com/forum/automotive_pictures/1639_ZX2_1.jpg
KING2018
Just new timing kit re-timed and went with the same firing order and it tries to start but nothing at all.
  • 110,190 POSTS
The firing order can't be changed... If it won't start, are you certain the ignition timing is correct?
CHEROKEENANNA
Other Category problem
1994 Ford Escort 4 cyl Two Wheel Drive Automatic 132. miles
what is the firing order
BMRFIXIT
  • 19,053 POSTS
[quote:7ef4c8690d="cherokeenanna"]Other Category problem
what is the firing order[/quote:7ef4c8690d]
firing order 1342
what is the engine size 1.8 L or 1.9 L
still 1342
need more
let me know
good luck
NTHAPELENG
I want to start but firing order I cannot put it right.
Good morning.
The picture with the cylinder location and the distributor set up is blow for you to view.
DANNYFRESNO
does anyone know it on a ford escort 1996
please
armadillo420 @ yahoo .com
RUDPRO
  • 224 POSTS
I'm assuming you have the 1.9 engine. Standing in front and looking at the engine, the cylinders are numbered 1,2,3,4. The firing order is 1,3,4,2. the distributor rotates counter clockwise. The number 1 plug on the cap should be the front right terminal, while looking at it standing in front of the vehicle.
DANNYFRESNO
your a very nice person thanx
also i thank this site
danny
