i own a 02 escort ZX2 i have trouble starting the car. somtimes the car will not start but if you wait a while it will start again i took the starter to get tested and it tested fine, also i did a volltage drop test on starting system and everthing tested fine, i replaced the starter relay and nothing, the other day i smelled somthing burnning and found that it was the ignition switch so i replaced it and thought that it would also fix my starting problem but it did not, i installed a remote start so when the car does not start i press the button and car startes just fine and starts fine after that for a while but then it does the same thing again
Sep 22, 2008 at 4:53 PM
