Mechanics
TRANS FLUID
1993 Ford Escort
Transmission problem
1993 Ford Escort 4 cyl Front Wheel Drive Manual 142000 miles
replace motor lost some trans fluild, can't seem to find a fill plug or any place to check it
Skeet06
October 30, 2008.
Hello -
I have attached a pic - item number 2 is the dip stick. This is where you check and service.
Make a small donation! (It will help us a lot. We really appreciate it)- information on your car can be found at: http://www.2carpros.com/kpages/auto_repair_manuals.htm
Information on your car can be found at: http://www.2carpros.com/kpages/auto_repair_manuals.htm
http://www.2carpros.com/forum/automotive_pictures/248015_Tran_Dip_stick_1.jpg
ImpalaSS
Oct 31, 2008.
Can't hardly see picture, but on the bottom it reads automatic trans mine is a 5spd manual
AD
Skeet06
Oct 31, 2008.
Hello -
Sorry late night........try this one.
Make a small donation! (We will make sure your question will be answered promptly and it will help us be able to continue to help others - Thanks)
Find a car repair manual for your car repair questions.
http://www.2carpros.com/forum/automotive_pictures/248015_Trans_1_1.jpg
Transmission Fluid Check
The transmission fluid level should be checked only with the vehicle parked on level ground.
Be sure the vehicle is on level ground and apply the parking brake.
Disconnect the electrical connector from the Vehicle Speed Sensor.
Disconnect the speedometer cable from the VSS.
Remove the VSS bolt and gently pry out the VSS.
Check the fluid level.
If necessary, add transmission fluid.
Position the VSS. Install the VSS bolt. Tighten the VSS bolt to 8-12 N-m (69-104 lb-in).
Connect the speedometer cable.
Connect the VSS electrical connector.
http://www.2carpros.com/forum/automotive_pictures/248015_Trans_2_1.jpg
Transmission Fluid Drain
Raise and support the vehicle.
Clean the transaxle drain plug area.
Remove the drain plug and drain the fluid into a suitable container.
Install a new washer and tighten the drain plug to 39-54 N-m (29-40 lb-ft).
Lower the vehicle.
http://www.2carpros.com/forum/automotive_pictures/248015_Trans_3_1.gif
Transmission Fluid Fill
Place a funnel into the Vehicle Speed Sensor (VSS) mounting hole.
Add the specified transmission fluid until the "full" level on the VSS is reached.
Connect the speedometer cable to the VSS.
ImpalaSS
Oct 31, 2008.
Thank you very much. Thought of adding fluid threw vss, but was sure how to check it or if there was a check/ fill plug some where thank you
Skeet06
Oct 31, 2008.
AD
