1989 Ford Escort no spark
1989 FORD ESCORT
79,000 MILES • 4 CYL • 2WD • AUTOMATIC
EUBANK37
no spark from ign. coil checked tach term. with light on start attempt.oh, engine turns but no spark. new distributor cap, wires, plugs all new as was needed besides there being a spark issue. checked plug to ign coil and power to one side (red) but not other (grn/ylw stripe) on start attempt. power to red side with ign in on position.checked continuity across all visible fused links ok.What else is in the line to block spark...a sensor? a fuse i am not seeing? I am getting fuel. could it be the ign module on distributor or ign switch itself.. as i said egine cranks strong just no spark! thanks I noticed inside the distributor when i had cap off inside right on the other side would be the module but on the inside molded to the inside of the dist.a tan-dark yellow half moon shape piece that had some dicoloration right down the middle(kind of a gummy dark substance i cleaned off just incase that is important!
Mar 9, 2009 at 10:25 AM
