Mechanics
PCV VALVE
2005 Ford Escape
Engine Performance problem
2005 Ford Escape 6 cyl Four Wheel Drive Automatic 100000 miles
could you provide installation information for the p.C.V. Valve on a 1995 ford escape with the 3.0 engine. Location is not a problem but removal of vacuum line and re-installing info. Is required.
A.burlatschenko
February 1, 2010.
2005 Ford Truck Escape 4WD V6-3.0L VIN 1
POSITIVE CRANKCASE VENTILATION (PCV) VALVE
http://www.2carpros.com/forum/automotive_pictures/12900_pcvv1_1.jpg
Removal and Installation
1.Disconnect the battery ground cable.
2.Disconnect the positive crankcase ventilation (PCV) tube from the PCV valve and position the tube aside.
3.Disconnect the PCV valve electrical connector.
4.CAUTION: A new PCV valve must be installed if removed from the valve cover. Damage will occur to the locking mechanism on the PCV valve. Rotate the PCV valve counterclockwise and remove the PCV valve from the valve cover.
*Discard the PCV valve.
5.To install, reverse the removal procedure.
Rasmataz
Feb 1, 2010.
AD
