Transmission removal
MIKEBROWN0203
  • 2001 FORD ESCAPE
  • 3.0L
  • 6 CYL
Is there a diagram or something to show the steps of removing a transmission?
Wednesday, July 23rd, 2014 AT 10:15 AM
HMAC300
  • 48,601 POSTS
Start by disconnecting the battery and then watch this video which shows the job being done on a similar car with diagrams and instructions below to show you how on your car.
https://youtu.be/6N6b5F2ChyE
Wednesday, July 23rd, 2014 AT 12:31 PM
DMARTELL
  • 2001 FORD ESCAPE
Six cylinder four wheel drive automatic 108,000 miles.
I started having problems with the transmission on my vehicle. When I put it into drive the rpm's rev very high like it is starting in high gear. When I manually place it in first gear I can start to drive. I can then shift to second and then to drive which allows me to drive the car, although it feels like I am going from second to fourth gear in that process. Reverse works okay. I took it to a repair shop and they told me the transmission needs to be replaced. Do you agree? What would it cost to rebuild the transmission? The shop told me it would cost between $3,200.00 and $3,800.00 to replace it with a rebuilt one (they will not rebuild mine).
Tuesday, June 25th, 2019 AT 4:21 PM (Merged)
  • 108,179 POSTS
Chances are they are correct. As far as the cost, that sounds high. However, I do not know where you live. I would estimate around $2,500.00. I would also recommend finding someone who can rebuild your transmission. That should help you save money.
LINDA A
Wow. We have a Ford Escape (2002). About one year or earlier after buying it, we began to have the same problems that you described. Because our vehicle was still under warranty, we had a new transmission placed in our Escape by Ford. After repeated problems with the same difficulties, Ford put in a "fix". Following thorough research and discovering that Ford had a history of problems with transmissions I became a relentless 'pit-bull.' You may want to ask the dealer (if you bought your vehicle there about the fix for transmission (valve fix). Since our transmission was fixed with their repair we have had no problems.
ZAMO95
I had a transmission problem with mine too about four years ago, but different issue and different transmission, mine was an automatic had overdrive light on for a while then started making noises and finally shut off on the road, of course was out of warranty.
I asked for dealer they wanted to charge me few hundred dollars just to diagnose the problem then if it need to replace the transmission they said over $3,000.00.
So I made some researches online until I came across this random guy who had a transmission shop, sent him an e-mail, he then called for more questions, scheduled a pick up because he had free towing, took the car did not know him or anything two days later he called said it will cost $1,400.00 and two year warranty, I agreed four days later called to get the car, everything went smooth and had my car fixed and still running fine like before.
So take your time and do not let people take advantage of you.
  • 108,179 POSTS
Good advice!
CHUCKIE46
  • 6 POSTS
  • 2001 FORD ESCAPE
  • 3.0L
  • V6
  • 4WD
  • 18,900 MILES
Want to swap trans I found an 05 trans my question will it work and where"s the id for the trans located
SATURNTECH9
  • 30,870 POSTS
They put the tags in all different places let me see if I can find out what years and models will fit but 2005 might not fit.
SATURNTECH9
  • 30,870 POSTS
The 2001-2002 ford escape and mazda tribute are the same transmission so you have a small window of transmissions.
CHUCKIE46
  • 6 POSTS
Any way I could change plugs on the trans the trans has low miles on it every thing elese should fit AND GITTING GOOD PRICE ON TRANS
SATURNTECH9
  • 30,870 POSTS
There could be a different bolt pattern up to the engine different gear ratios in the transmission etc. The only thing I can tell you is those are the makes and models and years that will fit. Its taking a big risk buying the transmission and if it doesnt work will they take the transmission back and give you a refund? I wouldn't take the risk when my transmission went out I went by the years make models that fit and used those for my donor transmission.
