Fuel Filter
1995 FORD CROWN VICTORIA
150,000 MILES • V8 • 2WD • AUTOMATIC
SAVAGEAR15
Trying to locate the fuel filter and replace. Please indicate anything that should be looked for while replaceing such as leaks
Feb 9, 2009 at 9:21 PM
DAVE H
  • CAR REPAIR CONTRIBUTOR
  • 13,384 POSTS
Its on the inside of the frame rail buy the fuel tank
REMOVAL
1. With engine OFF, relieve the fuel system pressure, refer to the Fuel Pressure Release Procedure. See: Fuel Pressure Release > Service and Repair
2. Raise the vehicle on a hoist.
3. Remove the push connect fittings from both ends of the filter.
4. Remove the fuel filter and retainer from the metal bracket by removing the two retaining bolts.
5. Remove the filter from the retainer. Note the direction of the flow arrow.
6. Remove the rubber insulator rings from the filter.
INSTALLATION
1. Install the rubber insulator rings on the new filter. If the filter moves freely in the retainer, replace the insulator rings.
2. Place the filter in the retainer with the arrow pointing out of the open end of the retainer.
3. Install the fuel filter retainer on the metal bracket and tighten the bolts to 9-12 Nm (80-106 lb in).
4. Install the push connect fittings onto the filter ends.
5. Cycle ignition switch from OFF to RUN position several times, without starting engine. Check for fuel leaks.
6. Lower vehicle.
See the picture below
Feb 9, 2009 at 10:11 PM
NAPPYBUTBALD
Can someone please tell me where is the fuel filter located on a 2002 crown Vic Lx. I have just spent 40 minutes under my car looking on the right side left side front and back and still i can not seem to found it.
Dec 8, 2018 at 11:50 AM (Merged)
MIKE H R
  • 3,094 POSTS
the fuel filter is mounted in line, under the passengers side, rear of wheelwell , next to the fuel tank
MARKODAVID
1993 Ford Crown Victoria V8 Two Wheel Drive Automatic
Where is the location of the fuel filter?
BLUELIGHTNIN6
  • 16,542 POSTS
Under vehicle, driver side, below seating area, front of rear wheelwell, mounted on chassis in fuel line
SJWWC
Engine Performance problem
2000 Ford Crown Victoria V8 Wheel Drive Type unknown Automatic 102,00 miles
Let it get low on gas, fuel light came on, right before turning in for gas, it started missing out. Filled it up, and when get to 30 to about 50 still cutting out. Where would the fuel filter be located. I am sure this is the problem as it started doing this when it was low on fuel. Thank you.
FLEXY5
  • 512 POSTS
Fuel filter is located on the drivers side frame rail.
