Rear axle stuck
FIREHAWKV8
  • 2005 FORD CROWN VICTORIA
  • 4.6L
  • V8
  • 192,000 MILES
I am removing the rear axle to change the wheel bearings which have blown. I have removed the wheel and opened up the diff, removed the pin and am now trying to push the axle in to pull out the c-clip. It will not move forward enough. After inspecting the axle, I found that the seal blew out and is now stuck inside the speed sensor ring and is preventing me from pushing the axle forward to access the c-clip. How can I get the axle off with the broken seal in the way?
Friday, July 3rd, 2015 AT 3:27 PM
WRENCHTECH
  • 20,758 POSTS
Nothing else should stop that axle from being pushed in. It's possible the axle is grooved and the bearings are sticking in the groove. Just hit the axle with a small sledge hammer. This video with show you how the differentials are very similar.
https://youtu.be/zarxKsspr3s
Friday, July 3rd, 2015 AT 4:49 PM
FIREHAWKV8
The '05 Crown Vic has rear disc brakes and the axle is stuck because the seal came out of the shaft and is now stuck between the speed sensor ring and the shaft housing. The axle will not slide in until the seal is removed from between the two. Any ideas on how to either get the seal back into the shaft or remove it so that the axle can move into the housing and give me room to release the c clip.
Saturday, July 4th, 2015 AT 3:54 PM
WRENCHTECH
  • 20,758 POSTS
There's no magic trick to getting this done. It has to come out one way or the other. Pull the axle out as far as you can and see if you can get the seal lined back up with a screwdriver
Saturday, July 4th, 2015 AT 4:25 PM
RYANTWASHINGTON
  • 2003 FORD CROWN VICTORIA
  • V8
  • 137,000 MILES
Can't get c-clips out because of spring between axle ends. It's a police interceptor.
Thursday, February 28th, 2019 AT 6:16 PM (Merged)
MERLIN2021
  • 17,250 POSTS
First, there is a tech bulliten on these axles have a look, if you dont use the new part numbers, you will do the work again.
AXLE - REAR AXLE SHAFT AND/OR AXLE BEARING PREMATURE WEAR TECHNICAL SERVICE BULLETIN Reference Number(s): 03-5-5, Â Date of Issue: Â March 17, 2003 Superceded Bulletin(s): 02-25-3, Â Date of Issue: Â December 23, 2002 Related Ref Number(s): 02-25-3, 03-5-5 ARTICLE BEGINNING DESCRIPTION AXLE - REAR AXLE SHAFT AND/OR AXLE BEARING PREMATURE WEAR - VEHICLES PRODUCED BEFORE 1/1/2003 ONLY ISSUE Some 2003 Town Car (except Limo and Hearse chassis), Crown Victoria and Grand Marquis vehicles produced before 1/1/2003, may exhibit rear axle shaft and/or axle bearing premature wear. This is caused by excessive load, temperature, and inadequate lubrication. ACTION To service, install Rear Axle Bearing Service Kit, Part Number 3W1Z-4A109-AA. Refer to the instruction sheet included with the service kit. PARTS INFORMATION PARTS INFORMATION WARRANTY INFORMATION WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage. WARRANTY INFORMATION FORD: 2003 Crown Victoria LINCOLN: 2003 Town Car MERCURY: 2003 Grand Marquis NOTE: This bulletin supersedes Technical Service Bulletin 02-25-3 dated December 23, 2002. Article 02-25-3 is being republished in its entirety to update the model line coverage. Part Number Part Name 3W1Z-4A109-AA Rear Axle Bearing Service Kit Operation Description Time 030505A Install Axle Bearing Service Kit 1.5 Hrs. Page 1 of 2 AXLE - REAR AXLE SHAFT AND/OR AXLE BEARING PREMATURE WEAR -200... 3/14/2009 Check your production date to see if it appies to yours,
https://www.2carpros.com/forum/automotive_pictures/62217_spring_1.jpg
Of course you need to pull that center pin the pull the spring out. Use the friction modifier with the new oil.
https://www.2carpros.com/forum/automotive_pictures/62217_toolsb_1.jpg
SHANNON
  • 2001 FORD CROWN VICTORIA
  • V8
What make and year of car will interchange with my 2001 crown victoria rear axle
WRENCHTECH
  • 20,758 POSTS
That is something that you need to ask one of the junkyards. They are the only ones that have the interchange books that tell you that.
JAILU
  • 1996 FORD CROWN VICTORIA
  • V8
  • 254,646 MILES
There has been a clicking, popping sound coming from my driver side wheel for almost two weeks. Today it looked as if my tire would fall off, next, I noticed the wheel began to shake. A friend took a look and said my axle was broken and could see it hanging. Im not familiar with cars, as you can tell, is it possible to get this fixed? Is this the true problem? What do I do from here? Please help me!
CARADIODOC
  • 33,752 POSTS
Is this a true problem? You have noises, the wheel IS about to fall off, and the wheel is shaking. Do any of those things sound normal? You avoided a serious crash so consider yourself very fortunate. Noises with the steering and suspension systems must never be ignored, but that is especially true with Ford products. They have more crashes due to parts separating than all other manufacturers combined. When that happens at highway speed, the question is will the vehicle head into the trees or oncoming traffic? Most Ford owners have their vehicles inspected yearly at a tire and alignment shop. In addition, two weeks is WAY too long to wait when you hear an unusual noise. Ford was famous for building some really dangerous cars. The Crown Vic is not one of them, but they should still be inspected periodically.
There are also legal ramifications to ignoring noises. If you had caused a crash that caused property damage or injury to someone, the lawyers would make a huge deal out of knowingly driving an unsafe car. We've also heard of cases where insurance companies refuse to pay damages when drunken driving, willful misconduct, and ignoring defects or causing unsafe conditions. They state in their policies that those are things they have no control over but car owners do. In our sue-happy society, you don't want to be on the hook for hundreds of thousands of dollars.
In this case the fact you noticed the wheel leaning at an unusual angle was the glaring clue. Most likely the lower ball joint came apart. That is one of the parts that holds the wheel in proper alignment. Your car is rear-wheel-drive so there's no axle shaft to come apart, at least as we normally think of a half-shaft on a front-wheel-drive car. Depending on how knowledgeable your friend is, the bearings on the front spindle could have come apart. That's not real common but it would allow the wheel to lean in on top. That is considered the axle, and is a less costly repair than ball joints.
Most likely you'll need a tow truck to get the car to a repair shop. If it's still drivable, go very slowly. Depending on what is wrong, it will usually adversely affect the braking system too so you could cause additional damage and / or need a longer distance to stop.
BARTOLO
  • 2000 FORD CROWN VICTORIA
  • V8
  • 84,000 MILES
Hello, mi car is a police interceptor, it has not traction control switch, and not lamp on instrument panel, how can I know is equipped with limited slip differential or conventional?
  • 31,937 POSTS
Hi there,
just jack up the drive wheels and turn one by hand, if the other turns in the same direction it is fitted with a LSD diff, if the opposite wheel turns in the other direction it is a conventional diff.
Mark (mhpautos)
