Mechanics
WINDSHIELD WIPER PROBLEMS
1997 Ford Crown Victoria
Engine Mechanical problem
1997 Ford Crown Victoria V8 Two Wheel Drive Automatic 110, 00 miles
Last year my wipers would not work when I had the left turn signal on but they were fine otherwise. Niow the wiper will only swipe the windshield 1 time when I turn the switch to on then it stops. Nothing else on the switch will work, no intermittent cycle and no washer fluid will come out. Do I need to replace the motor? It doens't make any noise either.
Ssolarz
August 12, 2010.
Have you checked the switch? Also, with the switch on, check to see if there is power to the motor and let me know what you find.
AD
