2CarPros - Car Questions & Answers
1998 Ford Contour Repair Question
Topics covered: Sensor, Coolant, Cooling fan.
Asked on May 12, 2007
1998 Ford Contour Temperature Gauge
My daughters 1998 Contour 2.0L ~120,000. The temperature gauge stopped working a couple of months ago. The car runs fine. She just graduated from college so were trying to save money. What is the best sequence of tests to find the problem? Where might these components to test be located? We do not have a repair manual. Thanks!
Avatar Asked by lherko
Answer
Replied on May 17, 2007
justanold, sorry for the delay...had to wait for my daughter.
1) the gauge does not move at all.
2) New York State, but why?
3) the radiator cooling fan does cycle.
Thanks Again!
Tiny Response from lherko
3 questions asked
Replied on May 23, 2007
Hello again Justanold... we did the test this evening on her weekly visit and the gauge pegged, so we'll be looking for a new temperature sender unit to install. My daughter specifically said to THANK YOU!
3 questions asked
Replied on March 5, 2008
Hi I have the same problem with my 1996 Contour - is there an easy way to access the temp sender? Mine is blocked by the coolant pipes
Tiny Answered by Karayz
1 question asked
Karayz,
It is a pain to get to but I can't answer your question. At the time my daughters car needed other work, So we paid about $40 to have the shop install the sensor. I did have to go to the dealer to get the correct sensor, that was another $40.
Regards
3 questions asked
Replied on July 9, 2008
My temp gauge does not move at all. My fan works and I removed the sensor and measured the resistance and it was 24K in room temp. I put it hot water and it went down to 8K and then I iced it and it went to 80K. It seems that the senosr should be fine but I don't know what I should read for the resistance. I shorted two sensor wires with a short jumper and the gauge did not move. You said short red/white wire. Which one? One of them or both?
More info. I also called Ford parts and they told me that I have taken out water sensor and I need to test water sender. Water temp sender is for the gauge and sensor is for overheating. My car does not overheat.
Tiny Answered by hajimow
0 questions asked
