cant find fuse box inside car
1999 FORD CONTOUR
226,341 MILES • 4 CYL
NODESI22
I have a 99 ford contour. i think that a fuse is blown for my blinker light and hazord light but i can not seem to find the fuse box on the inside of the car. Do you know where it is located?
Feb 17, 2011 at 9:33 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,350 POSTS
Hi!
Central junction box is located under driver's side of instrument panel. Central junction box may also be referred to as passenger compartment fuse panel.
19 - 7.5 Amp (Brown) Heated Rearview Mirrors
20 - 10 Amp (Circuit Breaker) Wipers
21 - 40 Amp (Amber) Power Windows
22 - 7.5 Amp (Brown) ABS Module
23 - 15 Amp (Blue) Backup Lamps
24 - 15 Amp (Blue) Brake Lamps
25 - 20 Amp (Yellow) Door Locks
26 - 7.5 Amp (Brown) Main Lights
27 - 15 Amp (Blue) Cigarette Lighter
28 - 30 Amp (Green) Power Seats
29 - 30 Amp (Green) Rear Window Defroster
30 - 7.5 Amp (Brown) Engine Management System (EMS)
31 - 7.5 Amp (Brown) Instrument Panel Illumination
32 - 7.5 Amp (Brown) Radio
33 - 7.5 Amp (Brown) Left-Hand Parking Lamps
34 - 7.5 Amp (Brown) Courtesy Lamps
35 - 7.5 Amp (Brown) Right-Hand Parking Lamps
36 - 10 Amp (Red) Air Bag
37 - 30 Amp (Green) Blower Motor
38 - Not Used
Relay Identification
R12 - White Relay Courtesy Lamps
R13 - Yellow Relay Rear Window Defroster
R14 - Yellow Relay Heater Fan Motor
R15 - Green Relay Wipers
R16 - Black Relay Ignition
D2 - Black Relay Reverse Voltage Protection
R17 - Not Used
R18 - Black Relay Express Down Windows
R19 - Blue Relay Speed Control Cut-Out
R20 - Not Used
R21 - Not Used
R22 - White Relay Fog Lamps
R23 - Black Relay Turn Signal
R24 - White Relay Left Panic Alarm Flasher
R25 - White Relay Right Panic Alarm Flasher
R26 - Not Used
R27 - Not Used
R28 - Not Used
R29 - Brown Relay Door Lock Control
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
Feb 24, 2017 at 3:28 PM
RUSTY200031
Electrical problem
1999 Ford Contour 4 cyl Front Wheel Drive Automatic
where is the fuse box in the car
Feb 24, 2017 at 3:28 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
The engine compartment fuse or power distribution box, is located adjacent to the battery in the engine compartment.
The interior fuse box is located under the driver's side of the instrument panel, it can be lowered for easier access by releasing retaining clips.
NICE
fuses box locations
The fuse junction panel is located to left of steering column and is attached to the instrument panel.
DARKANGLSBLUE
1997 Ford Contour
My power door locks stopped working, and I am wondering if it could be a fuse and if so where is that fuse box located?
Check fuse no.25 20amp left side of instrument panel and power lock control relay on top of right kick panel.
DARKANGLSBLUE
ok thank you! Now where do i find this panel ?
LILFLO71
Electrical problem
1998 Ford Contour 6 cyl Front Wheel Drive Automatic
My first question is where is the fuse box on this car? My heater blower is not working and my uncle thinks that the fuse is blown, so we can replace it. My second question is since I have own this car, I have had to replace the alternator every year. The car has been sitting for two years because of this, what is causing the alternator to go out each year?
JDL
  • 16,098 POSTS
There should be a fuse panel under the dash, driver side.
The power distribution center is under the hood, driver side. Your owners manual would show this and identify the fuses and relays. The covers for the fuse/relays may identify their purpose.
TREYZILLA
Interior problem
1998 Ford Contour 4 cyl Front Wheel Drive Automatic
What fuse is connected to the radio?
Feb 24, 2017 at 3:30 PM (Merged)
KERENSELF
  • 54 POSTS
Hi there!
Should be a 20 amp fuse in the INTERIOR fuse box. Look for the one marked #28......
