Directional flasher problem
C165RAZY
  • 2000 FORD CONTOUR
  • 2.5L
  • 6 CYL
  • 105,000 MILES
Turn signals wont work flashers wont work. But high beams do I changed the switch and the three prong flasher on the handle and tried 4 different handles nothing works. Everything else electrical works please help me
Tuesday, February 25th, 2014 AT 11:28 AM
HMAC300
  • 48,601 POSTS
Check the bulbs first to see if they work if you have changed themulti function switch then it's probably the flasher check fuses in central junction box first though. If it's the flasher it's the hazard switch
Wednesday, February 26th, 2014 AT 7:29 AM
FLORIDAGUY
Look at the passenger fuse panel, the top row fifth from the left is probably blown
Wednesday, July 10th, 2019 AT 12:33 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,895 POSTS
Excellent addition to this thread! Please feel free to help out whenever you are on the site :)
Saturday, July 13th, 2019 AT 12:47 PM
JASONPAIN
  • 1998 FORD CONTOUR
  • 4 CYL
  • FWD
  • MANUAL
  • 199,789 MILES
I have a 98 ford Contour and im replacing the flasher but I can not the flasher. How can I ifnd it
Saturday, July 13th, 2019 AT 12:48 PM (Merged)
Flasher/Turn signal relay-
Take the plast cover off the steering column between the steering wheel and the dash. It should be located right on top or on the side.
DEL_TORO345
  • 1995 FORD CONTOUR
Interior problem
1995 Ford Contour 4 cyl Automatic 135000 miles
My flasher will not stop "clicking". My turn signal works fine but the audible click will not stop. I was told it could either be electrical or the flasher itself. If it is electrical how do I repair it. How can I further diagnose the problem.
BLUELIGHTNIN6
  • 16,542 POSTS
I would suggest first testing the relay. Remove it and follow our steps on testing electrical relays found in our "how to" section.
BIKER222
  • 1995 FORD CONTOUR
  • 6 CYL
  • FWD
  • 777,103 MILES
Every thing works make a noise like the flashers are on when they are not and after a little while it send little smoke comes from the device
BLUELIGHTNIN6
  • 16,542 POSTS
If the turn signal (multifunction) switch is smoking then you will need to inspect the wiring to the switch and, most likely, replace the switch.
JIM B.
  • 1998 FORD CONTOUR
  • 6 CYL
  • FWD
  • 120,000 MILES
On my 1998 Ford Contour my flashers and directionals won't work after start up. After awhile they'll start working again. Any ideas?
  • 108,192 POSTS
Check both the ignition switch to make sure it isn't out of adjustment and check the multi-function switch on the steering column.
HANDICAP3
  • 1998 FORD CONTOUR
Electrical problem
1998 Ford Contour 4 cyl Two Wheel Drive Automatic
I know the flasher is not working I bought
A new one but I can't find out where it is.
Can you help me?
BLUELIGHTNIN6
  • 16,542 POSTS
Flasher is located in front seating area, located at turn and emergency warning indicator switch at steering column tube.
