1987 Ford Bronco Repair Question
Topics covered: Wheel, Axle, Four wheel drive.
Asked on January 28, 2010
4 wheel drive will not engage
Drive Train Axles Bearings problem
1987 Ford Bronco V8 Four Wheel Drive Automatic 78,000 miles
I just bought a 1987 Bronco, and I am pretty sure that the 4 wheel drive is not engaging. It has the automatic hubs and it is the push button 4 wheel drive system. When I push the 4x4 button nothing happens. the light next to the button does not turn on and neither does the indicator light in the dash. The same with the low range button. I am guessing that it is possibly a fuse out. Any suggestions on how to get the 4x4 to engage.
Answer
Replied on January 28, 2010
Actually, if you are not getting it in 4 lo, the actuator on the transfer case sounds like it is the problem. WHat you need to do is check to see if it is getting power to the actuator when the 4wd buttons are pushed. If it is, remove the actuator and have it checked.
LEt me know what you find.
