1993 Ford Aerostar
1993 FORD AEROSTAR
CD_USERCARPROS80
Engine Performance problem
1993 Ford Aerostar 6 cyl Four Wheel Drive Automatic 214k miles
I want to test if my maf sensor is defective. I remove the maf sensor with the electrical connector on and probe the green wire using a a paper clip and attach my multimeter red lead to it and the black lead to the negative battery cable or ground. Then I connect my vacuum pump to the platinum wire head. I turn the ignition key on. I turn the multimeter to ac voltage and it gives a .03 volt. As I applied pressure to the vacuum, the voltage didn't change a bit. Did I follow the right procedure to test if my maf sensor is defective? What other test should I do to test my maf sensor because when I start my engine cold, it stalls after a few seconds. I have to push the pedal to keep it from stalling. When I put the gear to the D position, the engine vibrates and very rough. I already clean the throttle body and check the resistance of the tb sensor and it seems nothing is wrong with it. Thank you for your advise.
CD
Jul 20, 2010 at 12:14 PM
